I just used a battery disconnect switch. I bought a few other types first but the connectors on them were garbage and not made for heavier gauge wire.
And being able to turn off the panels is very important. To you and the solar charge controller (SCC). SCCs do not like to have the panels connected first. They have a tough time deciding what to do with all that voltage as they wake up, so sometimes they let the magic blue smoke out of their brains. If you connect to battery power first, they can be ready for the PV power when it comes.
It's important for you if you have larger arrays. I can tell you that 48V @ 9A can be felt, but won't make you cry. 150V @ 20A will. Treat PV wires as you would household 120V wires.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL > GenY
1600W solar > 8400Wh LiFePO4 > Victron MultiPlus II > Cerbo GX
