Old 06-15-2024, 11:33 PM   #21
Thanks everyone. I'll keep the system on pretty much all the time except for any kind of maintenance, upgrade, electrical work , etc.
jma57 is offline   Reply With Quote
Old 06-16-2024, 07:15 AM   #22
Originally Posted by TacomaJoe View Post
I have mine on 99% of the time. The solar and shore power work together just fine.
The only time I shut my solar down is when my trailer is just sitting at home. if its an extended period (couple of weeks) I turn off the solar and the converter and let the batteries drain down some.
I'm assuming you have lithium batteries.
Letting lead acid batteries drain down is detrimental to them. Best life is sitting at float voltage.
Twinboat is offline   Reply With Quote
Old 06-16-2024, 10:00 AM   #23
Originally Posted by MGD1961 View Post
What brand or type controller is that. I知 factory trained with both Victron and Mastervolt and have never heard of any such thing.
There has been discussion regarding "connect battery first" but the most reasonable explanation regards 12/24 volt controllers. If the voltage output is automatically selected it's probably best done by battery connection first.
If the mfr puts no caution in their instructions they evidently see no issue. If they do it's best to heed them.
Old 06-16-2024, 12:42 PM   #24
Solar and Shore Power/Generator are 100% compatible. No need to disconnect solar when you have a shore power/generator supply.
The battery is in control, providing all the feedback needed to both the converter/charger in the camper and the solar charge controller.
Think of it like jump starting a car. The dead car relies on the host car for power to start. Once running, power is coming from the host car and the formerly dead car's alternator, and the battery in the formerly dead car provides the feedback to regulate it all with no muss, no fuss.
Set it and forget it.
The reason for the disconnect between the panels and the solar charge controller is primarily that the solar charge controller needs the feedback from the battery to know what to do with the power coming from the panels...mostly...and to have a place to send it. But bear in mind that the battery can be fully charged, and the solar charge controller can throttle back to just a trickle the current to the battery bank. The charge controller can handle the incoming power so long as it has a battery to tell it what to do with that power.
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 06-20-2024, 06:07 PM   #25
What brand or type controller is that. I’m factory trained with both Victron and Mastervolt and have never heard of any such thing.
I've read that in a Victron controller manual. Never have solar panels connected without batteries connected. I always put a disconnect on both.
ErnieSimons is offline   Reply With Quote
Old 06-20-2024, 07:22 PM   #26
I always practice and advise one to leave the batteries connected and the battery switch set to ON. Let the solar controller and converter controller do their jobs.
If one is doing maintenance, that is a different set of suggestions. Follow the solar controller manufacturers' procedures.
Bob
Bob K4TAX is offline   Reply With Quote
Old 06-21-2024, 09:06 AM   #27
Originally Posted by boondocking View Post
Use a controller that does not state "connect battery first"
That is a sensible precaution. Even with protection, the controller could be confused about the proper voltage for the storage system.
https://www.renogy.com/academy/solar...e-Solar-Panels
Chris Holt is offline   Reply With Quote
Old 06-29-2024, 07:40 PM   #28
Tom48's Avatar
Originally Posted by mysery1 View Post
I'd leave it on. If it was me I would want a disconnect for the solar panels, both positive and negative leads.
Ditto. Currently running 600 watts solar to 600 amps of LiFePo. And my inverter/converter will charge up to 102 amps when demand is there. They seem to work on harmony just fine.
PS. I WOULD SHUT OFF PANELS BEFORE I SHUT OFF THAT LEAF TO THE BATTERIES. You'd probably be just fine 9 out of 10 times but that 10th time you might fry your charge controller. The room is always battery power to the charge controller before the solar and vice versa when you're detaching.
Tom48 is offline   Reply With Quote
Old 06-30-2024, 09:00 AM   #29
It is common and acceptable in electrical work to color code conductors with tape.
Make everything clear. It is confusing enough when done right.
120v colors are black/hot, white/neutral, green/ground.
12v colors are red/hot, black/neutral.
ppine is offline   Reply With Quote
Old 06-30-2024, 11:39 AM   #30
And yet FR uses Red for battery positive connection and White for negative/ground.
Old 06-30-2024, 11:46 AM   #31
Trailer Park Supervisor
NJKris's Avatar
I always thought DC circuit black is ground/negative...or for the Brits.. EARTH!
Yes, I drink the water!
NJKris is online now   Reply With Quote
Old 06-30-2024, 02:26 PM   #32
I don't think there is any real standard color code for color coding 12v dc circuits in RV's. The automotive industry uses red/black but in my TT every negative wire is white and positive wires use a rainbow of colors.
For large wires, like #6 and larger, many use welding cable which is rarely available in other than red or black.
Old 06-30-2024, 04:04 PM   #33
NJKris's Avatar
ppine wrote DC circuit black/neutral. I've just never heard neutral used to refer to ground, only heard neutral used on AC circuits.
Old 06-30-2024, 08:57 PM   #34
JimM2109S's Avatar
And continuing to make DC circuitry confusing... in marine wiring, either black or yellow may be used for the ground wire.
2022 MiniLite 2109s
2018 F-150 XLT 4x4, 3.5L, Max tow pkg
2019 Ranger Lariat 4x4 (in reserve)
(We're just getting started!)
JimM2109S is offline   Reply With Quote
power, shore power, solar
