Old 02-12-2024, 08:40 AM   #1
Solar on the side port
It would appear that my solar on the side port is wired back into my trailer. My trailer also came equipped with a factory installed solar panel, unannounced to us.
I have an additional stand alone panel that has it's own controller. When I plug it into the solar-on-the-side port, my stand alone panel controller indicates no connection to the battery.
Does anyone know the wiring schematic with this situation?
I am considering re-wiring the solar-on-the-side connection directly to the battery so I don't have to remove the battery cover and use alligator clips to utilize my auxiliary solar panels for extra charging capacity.
Any thoughts or concerns?
Petes Popup is offline   Reply With Quote
Old 02-12-2024, 08:52 AM   #2
Welcome to the forum, I see it is your 1st post.
Your user name indicates you maybe have a pop-up?
Including the make/model/year of your R/V would be helpful in getting answers to your questions.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=50
Old 02-12-2024, 09:01 AM   #3
On mine, the solar on the side was directly connected to the battery with an inline fuse tucked under the frame.
A voltmeter would verify the battery connection and also check the polarity. The direct connection would work great for you since you have the controller.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
solar
