Originally Posted by Popeye47
No, straight into the roof which is also under the panel and then dicor
Can you remove the panel to gain access underneath, and leave the z brackets and Dicor as is? Even if there is no slack, you should be able to cut the wires under the panel to insert waterproof Ys, and then crimp on mc4 connectors to the wire ends. I got the items to do my solar project from Amazon. I recommend getting a good crimper if you tackle it.
