Old 06-23-2017, 01:55 PM   #1
OLDNAVY's Avatar
solar panel to controller
I just purchased a 10watt solar panel and a small controller for my TT battery charger. When I hook my panel up to the controller, nothing shows on the LCD screen when I place it in the sun. I have even switched my wires going to the controller thinking maybe I had reverse polarity or something.
What am I missing?
OLDNAVY is offline   Reply With Quote
Old 06-23-2017, 02:25 PM   #2
Kenny kustom's Avatar
Is it also hooked to the battery?
2017 Dynamax Isata 4
Old 06-23-2017, 03:40 PM   #3
OLDNAVY's Avatar
No. I was testing solar panel to controller. No battery but I thought controller would read energy from the panel
Old 06-23-2017, 04:47 PM   #4
Needs a battery too.
Old 06-23-2017, 05:03 PM   #5
OLDNAVY's Avatar
OK. It just doesn't make sense to me since all I want to see at this stage is the panel output. But, i'm stupid on this stuff....
Old 06-23-2017, 05:11 PM   #6
Flybob's Avatar
Many controllers state the following in the directions.
Connect battery to controller 1st then connect the load then the panel to the controller. Disconnect in the opposite direction. Many controllers will not start until they are connected to a battery. I think you will find 10W a little low as the parasitic draws in the TT will eat any output. I normally suggest a min of a 40W panel
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-23-2017, 07:17 PM   #7
OLDNAVY's Avatar
Thanks. I guess i"ll see when I hook it up
Old 06-23-2017, 07:24 PM   #8
Well it depends on the controller. The basic Zamp ZS-8 I have shows "fault" when not connected to a battery. Which controller are we talking about here ?
TheGerman is offline   Reply With Quote
Old 06-23-2017, 09:41 PM   #9
OLDNAVY's Avatar
Just says PWM RTD 10A
Old 06-23-2017, 09:52 PM   #10
Battery first
I have several panels that range from 50 watts to 160 watts. I have three different types of controllers and all of them require the battery to be connected first as was previously mentioned. The reason for this is that the controller has to know if it is attached to a 12V or 24V system before it can do anything.
Also note that most solar panels will lose most of their capacity if any part of the panel is in a shadow. For example: Today I had my 160 Watt panel connected to my TT and after a short time the corner of the panel had a shadow on it. It dropped from 8 Amps of charge to a fraction of one Amp charging. They need to be in the clear. This is also why I don't mount my panels on the TT roof. I like camping in the trees.
During the non-winter months my panels will recharge from the previous night's use of furnace, pump, and lights in a couple of hours. I have a generator in case of several days of cloudy conditions.
Have fun.
UT_Grandpa is offline   Reply With Quote
Old 06-23-2017, 11:33 PM   #11
That appears to be some generic chinese controller. In the manual it says under troubleshooting: Power off - Battery too low/reverse. Sounds this controller needs some power from the battery to operate.
Old 06-24-2017, 02:51 PM   #12
I was under the impression that 10 watt or less needs no controller.
markb422 is offline   Reply With Quote
Old 06-24-2017, 04:29 PM   #13
Yup. Got to have a battery. 10 Watts are barely going to register.
Less is More is offline   Reply With Quote
controller, solar, solar panel
