Originally Posted by hittheroadgeorge
Ok well so much for that.Lol I guess I will have to go to plan B.A guy I work with said he could do it.Maybe taking it to a RV place might be the best.Thanks for letting me know
Before you have someone else do it, please search this forum for 'Solar.' You will have to use and understand your system. I learned a lot from reading and posting questions. I started because I needed power for my CPAP.
I am almost done with my solar install. I am having a local RV repair shop install my Solar Panels because of my health.
The project included three major systems and a lot of smaller systems: Solar Panels, Batteries, & Inverter. Solar Panels feed into a Solar Charge Controller. The Solar Charge Controller charges your batteries. An Inverter gives you 120v AC. An Inverter should be Pure Sine Wave hardwired with an auto transfer relay.
I will still need to make improvements as I use the system and learn about issues.
My install thread:
Expanding compartment space for 2200 Watt Inverter/Charger
Good luck with your Solar install.
