Solar power question
I have an unknown solar panel on my roof. Estimates have been given at 75 watts. While replacing the battery today I put a volt meter on the cables (only two) with battery removed and no shore power. I had battery voltage, obviously it is from the panel. I am assuming this is normal, but is it correct? Would removing the array fuse from the controller stop this from happening to avoid shorting power to ground etc?
John
2003 1500 Avalanche 444,000 miles
2011 Rockwood ROO 23SS
