I bought a SUNER POWER 12V Waterproof Solar Battery Trickle Charger on Amazon ($60), about a year ago. I also installed a knife-switch that completely disconnects the batteries. So far, the solar charger has kept up the batteries 100%, and its onboard controller prevents overcharging.
I may have an advantage because the panel is in direct sunlight 100% of daytime, but I suspect it would still provide adequate charge under less than perfect conditions. The first charger I got had a bad controller, and after a phone call and quick troubleshoot, they quickly provided a replacement.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
