You would connect your solar panel clips to the positive and negative of the same battery, as said above they are wired in parallel, not series.
The amperage of that charger will do OK as a trickle charger to maintain the batteries when the RV is not in use and the battery cutoff switch is in the disconnect position, they won’t provide enough power to make much difference while boondocking.
(Previous) Coachmen Mirada Select 37RB
(Previous) Coachmen Freedom Express 246RKS
(Current)2022 Grand Design Reflection150 226RK
2022 F150 Powerboost Hybrid.
