Old 04-01-2010, 11:36 AM   #1
tmmar's Avatar
Still getting battery corrosion in compartment
I am getting some battery corrosion on the battery compartment floor where my batteries are housed. I did the mineral oil in the cells that some recommended. It helped somewhat, but I still get corrosion in the compartment. Any other suggestions as to how to prevent this?
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-01-2010, 12:11 PM   #2
Clean extremely good with baking soda water combination, all the baking soda you can dissolve in warm water. Then strip the paint to the metal and do again. Then prime and paint with acid proof paint. Should be able to find it online at Aircraft Spruce. Airplanes use this in their battery compartment to prevent corrosion due to bouncing and acid seeping out during maneuvers. Make sure you get acid proof paint.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-01-2010, 12:42 PM   #3
NWJeeper's Avatar
Acid paint would be my suggestion as Windrider suggested. Also, to my knowledge NO battery manufacturer advises adding anything other than distilled water to batteries, even the additives that are billed for use in batteries shows no actual advantage in most studies I have seen (except the ones by the companies trying to sell you the stuff). I hope you didn't just ruin them by putting mineral oil in them. The problem is that they are off-gassing while charging which is normal. Keep a close eye on them while in storage and keep the water levels up on them.
Ed & Wendy
www.nwjeepn.com
Old 04-01-2010, 12:46 PM   #4
tmmar's Avatar
Mineral oil, being lighter than the acid/water, floats on top. It doesn't mix with the water at all. So far (it's been several months) it appears not to have affected the batteries in any way.
Tom and Margaret
battery
