From the above link:
Can I Use My Present Progressive Dynamics PD9200, PD4000 or PD4500 Series Lead/Acid Units With the Charge Wizard to Charge My Lithium Battery?
Yes, if you are willing to live with an expensive battery that is only partially charged. The Normal Output voltage of the PD9200, PD4000 and PD4500 Series voltage provides only 13.6-volts and a full charge voltage for Lithium needs to be 14.4 – 14.6 Volts. The PD9200, PD4000 & PD4500 Series Charge Wizard will initially jump to 14.4-volts in the Boost Mode when first connected to 120 VAC power and will remain there until the battery voltage reaches 13.8-Volts, then automatically drops down to the Normal Mode of 13.6-Volts. The faster charge rate of Lithium means that in the Boost Mode it will reach this 13.8-Volt point after only a few minutes of recharging and then the charging current will drop to ZERO AMPS and will not add any additional charge to your Lithium Battery. This lower charge state will not damage your battery, but will eliminate most of the advantages you paid for.
Our Georgetown came with a Progressive Dynamics PD9270 Converter. The PD9160LAV Lithium version is about $220 from Amazon so the rest is in the actual battery system:
https://www.amazon.com/Progressive-D.../dp/B07DP3X16F
The 70-amp version is about $20 more from BestConverters.
Still, if I were due for a house battery replacement and were contemplating AGM batteries or four golf cart batteries to replace the two lame 12 V standard house batteries the cost difference gets even smaller and I'd have a weight savings. Assuming they would fit in the same physical space.
Ray
