Originally Posted by MamaLaura
Greetings O'Wise Ones!
I searched through previous threads but didn't see the answer so here I go...
I have recently purchased a 2902WS with 50amp service and want to buy a surge protector. Easy peasy you say! Here is my question and maybe I'm just not smart enough to see the answer plainly... Since my cord and connections are 50 amp, what size surge protector do you recommend I buy? I've been to camp grounds that have max 30 amp plugs in which case I have to use the 30 to 50 adapter and so if you put the protector in the campground outlet, you have to have 30amp surge protector. But if you are at a place that has 50amp, you need a 50amp surge protector. I KNOW I'm not the only person with this issue so how did you solve the challenge?
You need a 50A surge protector. If camping in 30A, use an adapter, plug the surge protector into that, and the trailer into the surge protector. This is assuming you are looking at portable ones. I HIGHLY recommend you look not only at a surge protector, though. I would look at the EMS units by Progressive Industries. They also monitor for high and low voltage, open ground, 220V and so on.
https://www.progressiveindustries.net/ems-pt-x
I personally prefer the hardwired version found here:
https://www.progressiveindustries.net/ems-hw50c
This unit has a remote monitor that allows you to see any error codes and also monitor your amperage usage from inside the camper- VERY handy if you're on 30A service.
