07-31-2016, 10:48 AM
synthetic oil for onan generator
I've looked at past posts and there seems to be many being that recommend using synthetic oil in the generator. I have an onan 5500 lp generator and it's time to change the oil. based upon the temperatures where we live (below freezing to over 100) the recommendation is to use 15w-40 oil. so I tried to find a brand of synthetic oil in this viscosity. I couldn't find any. all the ones that are 15w-40 are for cj service (diesel engines). so my question is what are people using? (brand, viscosity, gas or diesel, and is what they are using the same as what is recommended?
thanks
07-31-2016, 12:29 PM
I have used Castrol Edge full synthetic in 5W30 viscosity in my 2 Honda generators and my lawn mower for at least 6 years. My Hondas are 10 years old and still purr like new. My temp range is about the same as yours.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-31-2016, 12:38 PM
I belive rotella systhec has rating for gas engines
07-31-2016, 12:56 PM
Never used it before, but, Royal Purple might work
07-31-2016, 02:28 PM
You should use only the oil recommended by the manufacturer.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-31-2016, 02:48 PM
Why? If the oil has the same specifications as the recommended I'd rather not support the manufacturers partner just because.
08-01-2016, 01:30 PM
Shell TD6 available at Walmart. Used in a lot of diesel motors but also used in gas motors. I also use it in my Can Am ATV.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
08-01-2016, 01:39 PM
Looked at my jug of shell Rotella T6 and noticed it is 5/40 weight.
08-01-2016, 01:42 PM
Amsoil makes full synthetic 15w40
08-01-2016, 02:00 PM
So does Schaeffers oil. Whatever you choose... make it one you can find anywhere cause you never know when you will need it. I also HIGHLY recommend it meets or exceeds OEM specs.
2017 Puma 297RLSS
08-01-2016, 02:01 PM
thanks
The rotella will work just fine . 15/40 or even 5 /40 is ok once the oil is warm the viscosity increases to the 40 wt . the 5 wt is good for flow when it's cold but won't make a difference if it's 90 out
08-01-2016, 06:31 PM
With respect... if you have never used it before why would you recommend it over any other oil? Why recommend something you've never even tried?
__________________________________________________ ___________
2013 Sunseeker 3170ds
08-01-2016, 06:56 PM
Well, bbrown thought the op was asking for recommendations. I personally use Amsoil for everything, but know of people that have used Royal Purple for their gennys. I would have mentioned Amsoil but lot of people dont know where to get it.
08-01-2016, 07:18 PM
Amsoil. Its on the web. Its WAY to easy to buy. I'm a dealer. Go online. Set up a personal account and buy. Amsoil is THE first synthetic oil. And, in my opinion, the best.
David and Vicki
19-month-old English Springer Spaniel "Sadie"
2019 Silverado LTZ Duramax
2023 GDRV Reflection 150 226RK
08-02-2016, 07:54 AM
Is there a such thing as straight 30w syn.? Cummins Onen recommends 30w is best at temps similar to our summer temps.
08-02-2016, 07:55 AM
There is. Amsoil offers that too.
08-02-2016, 08:13 AM
X2
2021 Forest River Vengeance Rouge Armored 371A13
2021 GMC Sierra/Denali 3500HD SRW
Anderson Ultimate 24k Hitch
08-02-2016, 01:00 PM
I used Wal-Mart 10-30 synthetic in my last unit for 8 years/600 hours no issues.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
08-03-2016, 07:38 PM
reg or synthetic
I went to Cummins to buy oil for my Onan diesel generator 3200, in my MBS 2401R Forrester. I asked for synthetic but was told by the service and parts departments to only use regular oil. So I have only been using regular. I don't know why but the Cummins folks said that they would not recommend using synthetic in their generators. Got me?
08-03-2016, 08:02 PM
Something doesn't sound right about all that. What does your Onan manual tell you to use?
David and Vicki
