Tail Light Replacement 2018 Coachmen Freelander
Hello, I need some advice on how to replace a faulty tail light assembly on a 2018 Coachmen Freelander. It is an LED fixture with 3 lights. The middle light is the backup and the top and bottom lights are turn signals/tail lights.
On the original fixture there are 8 wires feeding it - 3 white, 3 black and 2 red. On the replacement fixture I bought there are six wires feeding it (white-ground, blue-backup, green-high mode, yellow-high mode, brown-low mode, and black-low mode.
So I need to connect 6 wires on the new fixtures to 8 wires on the Freelander. I assume I need to use a multi meter to track down what is feeding the old fixture on what wire. I need some help in doing that and then figuring out what wires on the Freelander get connected to what wires on the new fixture.
The existing light is Command Electronics and the new lights are Partsam.
