Old 03-12-2020, 01:53 PM   #1
Temp living in 2020 forest river hemisphere 34rl
Have a question I recently bought a 2020 forest river hemisphere Salem elite 34 rl with the 50 amp plug, what voltage should I run to it. Going to be living in it temporarily so will be using everything alot?
Thank you
Newbierv00
newbierv00 is offline   Reply With Quote
Old 03-12-2020, 02:01 PM   #2
240V split phase
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 03-12-2020, 02:44 PM   #3
If temporary you can use 30 amp 120 volt and a dog bone using only 1 AC.
Old 03-12-2020, 02:54 PM   #4
DavidBo's Avatar
We've had a lot of posts about folks attempting to adapt 220V clothes dryer outlets for RV use and end up doing serious damage. Only 110 volts should ever be applied to the rig, if uncertain about how to do it an electrician competent in RV requirements is a must.
DavidBo is offline   Reply With Quote
Old 03-12-2020, 02:59 PM   #5
Kanadian Kamper
kenandterry's Avatar
Here ya go
ID:	225030   Click image for larger version
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 03-12-2020, 03:22 PM   #6
50A is 240V split phase. Yes, an electrician should be called if you don't know how to wire 240V split phase.
forest river, hemisphere
