01-19-2021, 09:32 AM
The Shining (where is fuse panel?)
Back again.
I now know how Jack Nicholson felt when lost in the maze.
Can not locate the fuse panel......and, not sure if new camper has one.
2021 Forest River "Salem" FSX 177BH
Understand you should always have extra fuses.
Thanks in advance.
01-19-2021, 09:40 AM
It's going to have one. Most times the 12 volt DC fuse are in the same panel with the 120 volt AC circuit breakers.
 2011 Flagstaff 831 RLBSS
If I eat myself will I become twice as big?...or disappear all together?
01-19-2021, 10:03 AM
Have you looked in the panel under the bottom bunk?
2016 Salem 27RKSS
01-19-2021, 01:11 PM
Just as confused as you
Walk to the refrigerator, turn towards the bunkbeds, look down, open the breaker panel by pushing briefly on the door.
https://my.matterport.com/show/?m=mM5YgaNJArd
This is the same answer for your post yesterday. https://www.forestriverforums.com/fo...ox-223612.html
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
01-19-2021, 02:13 PM
Originally Posted by Scrapper
The site team just now deleted yesterday's mentioned post due to this rule: "Do not post the same discussion topic more than once or in several areas of the forum."
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
01-19-2021, 06:04 PM
Yes, that is it. Thanks.
When plugged in, the fan seems to run all the time. Is that normal?
01-19-2021, 10:15 PM
The converter fan? If so, my fan runs a lot. Basically any time there's a 12v load somewhere like lights, battery charging, fridge controls, etc.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
01-19-2021, 10:53 PM
Usually means the converter is dealing with a low or bad battery.
01-20-2021, 08:52 AM
Ray
Thanks, will check battery.
01-20-2021, 08:53 AM
01-20-2021, 09:21 AM
X2.. I agree.
But... I also want to mention that on my last two R/Vs, anytime there was a large load on the 12v system my converter fan runs. Under large loads, the converter is outputting a lot so it only makes sense the fan would run to keep it cool.
When I say large loads I mean MORE than just one or two lights at a time and a refrigerator/water heater control board.
Even when my batteries (which are good) are fully topped off and we come in and turn on ALL the lights and a couple ceiling vent fans on high, the converter fan runs.
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=60
01-20-2021, 11:57 AM
Originally Posted by 5picker
X2.. I agree.
I recall reading on one Converter mfr's website that their cooling fan came on whenever the load on the converter exceeded 10 amps. That makes sense as a 10 amp load is ~125 watts and I remember how hot a 100-120 watt light bulb got (back when they were still used widely).
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
01-20-2021, 02:01 PM
If the load on the converter output is 10 amps, or ~125 watts, that 125 watt heat is dissipated by the load devices (lights, roof vent motor, etc). The heat that the converter fan must dissipate is only the heat generated from losses within the converter circuitry, which I certainly would hope is not an additional 125 watts. If it was, the converter would be quite inefficient.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
