Dealer replaced, took about 11 hours, as they had never done the exchange prior. Crazy occurrence, shutdown everything. But the replacement has worked well. The replacement is a wire to wire transfer from one board to another. The new CPU board requires all single terminate wire ends to be cut off and wired in to plastic harness that has bare wire leads. These harnesses plug into the CPU board. No longer is each individual wire landed on to the board as I understand it. The problem is the CPU board under the sink. But both CPU and touch panel where replaced. So far good experience if ya have to have it happen.
