Old 07-11-2020, 05:05 AM   #1
Transfer switch?
we have a 2007 sandstorm and we have an electrical problem. The outlets were working when the generator was running and now they don't. We were told it was probably the transfer switch. We could use some help locating a wiring diagram and some hints on where and how. We need them running to run a cpap while camping. Any additional hints would be appreciated.
DESAREE is offline   Reply With Quote
Old 07-11-2020, 05:17 AM   #2
bikendan's Avatar
Sorry but a wiring diagram doesn't exist.
You might try asking in the Sandstorm sub-forum. But you should post which model number you have.
Equalizer WDH
Old 07-11-2020, 07:47 AM   #3
Head Rambler
Do they work on shore power?
Have you checked all the receptacles to see if a GFCI is tripped?
Have you checked the breakers on the generator itself to see if they're tripped?
If it is the transfer switch we'll need the make and model to get a diagram for it.
Gotta go campin!
Old 07-11-2020, 07:51 AM   #4
Hmm.
I've seen wiring diagrams for other models and years. Yes, they work when plugged into shore power, the cgfi won't reset, and one breaker switch was tripped but reset. I'll find the model. Any idea where the transfer switch would be?
Old 07-11-2020, 07:53 AM   #5
Model
T23FLSP is the model
Old 07-12-2020, 09:53 AM   #6
If your GFCI outlet will not reset, then there is no power to that outlet. So go backwards and see if the breaker has power.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
switch, transfer switch
