09-25-2015, 08:00 PM
Trickle charging during winter 12 v
I'm storing my new Rockwood 2514g pop up camper outdoors this year. It will be winterized and covered well, but I am taking home my battery and store it in the garage. I want to hook up a trickle charger. I saw a Black and Decker BM3B, 12 v charger / Maintainer. It basically performs trickle charge technology throughout the winter season..... Without you doing any thinking on maintenance for the battery during the off season. Since this is my first go round does this sound like the right choice? Thanks
Dutchmen
09-25-2015, 08:07 PM
Looks fine. One safety suggestion: Keep the maintainer 2 or more feet from the battery and anything flammable. I had a buddy have 2 maintainers fail and burn from voltage spikes in his utility power. Almost burned down his garage with cars and motorcycles in it.
09-26-2015, 12:17 PM
Buy one of these. set it for 1 hour in any 24 hour period. plug your trickle charger into it.
You wont boil the battery and it will keep it topped off.
Canarm KHG303 24-Hour Plug-In Timer Switch Electric with One Outlet - GreyDock.com
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
09-26-2015, 10:39 PM
2 good suggestions. I'll take the good advice. Thank you both😀
Dutchmen
09-26-2015, 11:20 PM
I used to remove my 2 Interstate marine/RV deep cycle batteries and leave them in parallel on an automatic trickle charger all winter in the garage. Never used any water and the batteries were still in excellent shape after 9 years.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
09-27-2015, 02:56 AM
09-27-2015, 11:34 AM
Also, never set a battery on concrete, it will still discharge with the maintainer. keep it on a block of wood or a shelf.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
09-27-2015, 11:57 AM
I use battery tenders (brand name) year round. They are intelligent chargers so you won't overcharge and burn off electrolyte solution.
09-27-2015, 12:16 PM
X2
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
09-27-2015, 12:23 PM
If you are using a maintainer / charger I would not put it on a timer. I know the one I have will go through a charge cycle when you first hook it up then it will go into a maintenance mode. If it is a good quality maintainer it should not boil your batteries.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
09-27-2015, 12:57 PM
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-27-2015, 01:30 PM
A good maintainer should hold the battery at 12.7-13 volts. Much over 13.5 will lose electrolyte and affect battery life.
09-27-2015, 01:59 PM
Agreed if you are using a maintainer then do not use a timer.
I use a multiple output maintainer in the boat. It's mounted inside the boat and keep the batteries charger all winter long. I just plug in the boat and don't have to think about it all winter long. My batteries are lasting longer than ever and I don't have to pull then from the boat as part of my winterizing program.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
09-27-2015, 02:17 PM
I guess this makes x4 for battery tender.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
09-27-2015, 02:44 PM
x5 I have 2 6v batteries and 2 battery tenders
the ones I use are from Canadian tire (NOCO Genius G1100 Smart Battery Charger)
09-27-2015, 03:16 PM
Urban legend...
09-27-2015, 03:19 PM
Originally Posted by Flybob
IMO Best of all of them. We put them on anywhere from 4 to 8 race cars and a couple ATV's and Golf Carts (pit vehicles) all winter long. Never came back to a bad battery.... They make a unit that charges 4 batteries at a time. We use those and a couple of the Battery Tender Jr.s
09-27-2015, 03:22 PM
Four six volt and two twelve volt here. Battery tenders are cheap insurance against expensive replacement.
09-27-2015, 03:24 PM
This used to be the case many many many years ago. Today's batteries being incased in a type of plastic has resolved this issue....as someone else mentioned...Urban Legend!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
09-27-2015, 03:46 PM
I use a Battery Tendr, same type that I use to keep my motorcycle and golf cart batteries charged over the winter. BTW my motorcycle battery is going on 10 years old and I think this year I'm going to change it because I know it's gone above and beyond its rated life.
2015 Puma 31BHSS, 2005 Chevy Silverado2500HD
