04-01-2017, 11:11 PM
trimetric monitor and contoller
thinking about ordering the tm 2030 charger and the sc2030 for charging to go with my 3 100 watt renogy panels .....does anyone use or have expiererance with that set up
04-02-2017, 05:52 AM
I did a lot of research before buying and electrical is sort of a thing for me. Bogart (Trimetric and SC2030 solar controller) are in my opinion by far the best combination available for both solar as well as general battery condition monitoring in RVs. There are a lot of reasons and if you need some specifics, let me know. The SC2030 is a 30 amp solar controller and uses PWM technology...and communicates with the Trimetric that results in a lot of advanced features.
2015 335DS
04-02-2017, 06:48 AM
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
04-02-2017, 07:17 AM
Nice reference...sort of says it all for the average reader. BTW, some feel that the Trimetric, when installed in that white PVC junction box, looks something like what you would have found on "the Apollo capsule." Can't disagree, you can order the TM-2030A model and just cut a square hole in the plywood panel where you want to install it and mount it flush...much more 21st century!
One bonus feature is that the 2030 charge controller gets its battery voltage data from the Trimetric, measured right at the battery lug, so it automatically compensates for voltage drops in the controller to battery cables, making large conductors unnecessary.
2015 335DS
04-02-2017, 07:27 AM
One bonus feature is that the 2030 charge controller gets its battery voltage data from the Trimetric, measure right at the battery lug, so it automatically compensates for voltage drops in the controller to battery cables, making large conductors unnecessary.
If I were to build a camping trailer from the ground up it would be styled after the interior of a spacecraft.
04-02-2017, 08:56 PM
I use the trimetric controller and monitor with 200W ROOF MOUNTED And 200w portable I can just plug in in parallel. have been using for two years and would not even consider anything else after using. Always know where batteries stand. seldome have to use 200w portable except when in shade.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
04-02-2017, 09:06 PM
Hi,
I have that monitor/charger combination with 300 watts on the roof.
I couldn't be more pleased with not only the way I know what is going on with my power system, but also the support I got from the company as I set it up.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
04-08-2017, 10:20 PM
Senior
Scott i thought the same thing about the color of the box for the SC-2030RV. Fortunately I bought the TM-2030 and SC-2030 controller at the same time and the controller came with the same box in black so I swapped the boxes since the controller In my installation is concealed. I thought briefly about mounting the TM-2030RV panel flush but didn't trust my skill with cutting a hole in a recessed panel with only 1/8 inch of an overlap.
04-09-2017, 10:28 AM
It IS a tight hole to cut!
Dave W AKA "Toyman"
Well modified Forester C 2551
Why ?...Why not ?
04-09-2017, 11:22 AM
Yep...that is why I bought the 2030-A, didn't like the colors but really easy to flush mount. I too would have preferred the white, but it is too difficult to cut a hole that tightly.
2015 335DS
