Originally Posted by Gandolf77
Thanks for the info but that converter power center is farther back on the trailer. It might be easier to try to run a wire to the battery disconnect switch. Both of these solutions require running a wire along the bottom of the rig and coming up through the floor. Drilling a hole through the floor is problematic as I do not know where other things are routed. Any guidance here?
Regardless of how or where you wish to connect to 12 volts, you must run a Pos and Neg #10 gauge wire from the source to the needed location. You must include a fuse in the Pos line at the battery if you run from the battery.
As to where to drill a hole.........that's the wonderful part of a DIY installation of anything. Experience is a good teacher. If the results were good, then one learned something. If the results were bad, well one learned something there too. One hopes it wasn't too expensive of a learning experience.
Bob
