Old 06-26-2024, 08:40 AM   #1
TV picture freeze when opening lights
Hello!
Just trying to figure out why TV reception freezes when we turn on certain lights. We have the old Winegard antenna but we think the problem is mostly electric.
Anybody ever experienced this?
Thanks in advance for any help!
Grangalo
2014 Rockwood Windjammer 2809W Diamond package.
grangalo1812 is offline   Reply With Quote
Old 06-26-2024, 08:42 AM   #2
Originally Posted by grangalo1812 View Post
Hello!
IIRC, I've seen other people report this problem with certain LED lights. Try changing the lights with different bulbs.
Iwritecode is offline   Reply With Quote
Old 06-26-2024, 08:48 AM   #3
if you can trace your wiring for the TV and antenna
make sure there is NO other wire running alongside it
DC current is good at creating electrical interference
if they are tied together ... loosen them
OR
magnets placed on the wire may reduce the loss
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-26-2024, 09:04 AM   #4
Here are some older threads I found talking about the same problem.
https://www.forestriverforums.com/fo...hts-74214.html
https://www.forestriverforums.com/fo...ts-126415.html
https://www.forestriverforums.com/fo...hts-43307.html
https://www.forestriverforums.com/fo...-tv-46968.html
Old 06-26-2024, 09:12 AM   #5
I like this answer from the list
use a length of coax cable to bypass installed antenna wire for testing
If it works then you know it is wiring interference
https://www.forestriverforums.com/fo...ml#post1417595
Tarpon Springs FL
2022 Salem 24RLXL
Old 06-26-2024, 09:21 AM   #6
D W
D W's Avatar
Frequency interference from the LED's. My awning lights do the same thing to my reception. As we never need the awning lights during camping season it's never a problem.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 06-26-2024, 09:56 AM   #7
RFI
OR
They may look like magnets, but they are NOT. They are ferrite beads, sometimes referred to as chokes. With every current flow there is a corresponding magnetic field. (Don't believe it? Hold a compass near a DC single conductor--not a duplex pair--and turn the current on and off and watch the needle jump.)
Running a conductor carrying current with a high-frequency component through a ferrite bead suppresses the magnetic field, and consequently the high-frequency current.
As you know, the US FCC tests devices to see if they produce enough emissions to interfere with other devices. This is called Radio Frequency Interference (RFI). These devices need to have the high frequencies (sometimes called radio frequencies or RF) internally, and are often packaged in a grounded metal case which contains the electric field. The RFI emission comes from unshielded cables which radiate the electric field acting as an antenna. The longer the cord, the stronger the radiation.
The ferrite bead (not a magnet), installed close to the source, prevents the RF energy from propagating down the cable and becoming an efficient radiation source.
Larry
Larry-NC is offline   Reply With Quote
Old 06-26-2024, 09:57 AM   #8
so that's why they never stuck to the body work
Tarpon Springs FL
2022 Salem 24RLXL
Old 06-26-2024, 10:33 AM   #9
Here you go!
Here you go!
Larry
Old 06-26-2024, 04:09 PM   #10
Thanks for the replies everyone 😀
Will try out some of the troubleshoothing suggested!
Grangalo
light
