Originally Posted by Macrosill
Just some food for thought:
A 50 amp RV outlet is a 220v single phase supply. While it is a single phase it has 2 legs that are often referred to as separate phases for easy of understanding. A 30 amp RV outlet is 110v single phase supply. Depending on your coach or trailer and the appliances inside you may cause more harm than good by using 2 30 amp feeds. It is possible they would be fed on the same leg and not provide a 220v supply. This can become an issue with a shared neutral service, like in a 50 amp RV installation in your coach or trailer.
I know of no common R/V's that have 240v appliances, everything is 120v.
The R/V is wired in such a manner that nothing uses 240v.
That's why the dogbone adapters (from 50 to 30) which tie both legs of the 50 amp service together to feed off a 30 amp service will work.
