Old 03-30-2021, 09:03 AM   #1
CampItOut
campitout's Avatar
USB/12VCig lighter socket
Have a 2019 2109S minilite and the bedside charging station with USB and cig lighter socket has suddenly quit charging. Checked with multi meter and there is no power to the station. I have checked all the fuses on the converter/inverter below the fridge and they are all good. The USB charger on the radio/DVD player works. AM I MISSING SOMETHING?
campitout is offline   Reply With Quote
Old 03-30-2021, 09:06 AM   #2
Many of those charging stations have their own fuses. You have to remove it from the wall and check.
NavyLCDR is offline   Reply With Quote
Old 03-30-2021, 09:42 AM   #3
CampItOut
campitout's Avatar
Yup, checked the fuse and its good, even removed the fuse and direct wired but nothing.
Old 03-30-2021, 10:32 AM   #4
Did you check for 12 volts on the wires going to the charger?
Old 03-30-2021, 11:08 AM   #5
CampItOut
campitout's Avatar
Yes, no power at all coming to the station 12V or 110. I was assuming it was between the converter and the station since the fuses in the converter/inverter and station are good. Last resort would be to wire trace and I know that will not be fun since a lot of those are hidden and almost impossible to see or get to.
Old 03-30-2021, 11:09 AM   #6
CampItOut
campitout's Avatar
I was hoping it was something as simple as a line fuse or something I had overlooked but turning out to be not so. UGH
Old 03-30-2021, 01:39 PM   #7
Might want to check the connections at the back of the converter. Might be a wired pulled out, especially if the DC
negative wires are in a bus bar.
Old 03-30-2021, 03:54 PM   #8
CampItOut
campitout's Avatar
Good idea, will check that and let you know, Thanks
Old 04-07-2021, 09:53 PM   #9
CampItOut
campitout's Avatar
No wires loose or pulled out, turning out to be a mystery.
light
