USB wall charge plug causes lights to flicker
I have a 2021 Alpha Wolf 26RL-L trailer and I replaced the proprietary Bluetooth speaker wall mounted charging port beside the bed with a wall mounted standard USB charge plug (exact same plug used throughout the trailer, ordered from Forest River). The swap was very simple, 12v wiring going to the proprietary charger worked for the USB charge port.
The problem that I am running into is that whenever anything is plugged into the USB charge port (e.g. a smartphone to charge it), the 12v lights in the bedroom flicker between normal brightness and dim. I checked the wiring connections to the USB charger and confirmed that I have a good connection, but the flickering still happens. Does anyone have an idea of what might be causing this, and a suggestion on how to fix it?
Thanks,
Mark
