07-29-2020, 01:15 PM
Using 50A Outlet for 30A RV
Any issues with getting an adapter and plugging my 30A trailer into a 50A outlet? Sometimes parks fill up and this is the only thing available.
07-29-2020, 01:26 PM
Nope, not at all.
We run our 50A trailer most of the time on the 30A side. We don't need the 50 Amp in our trailer, but it's pre-wired that way for dual A/C units. You should be good to go, unless you're running 2 or 3 A/C units at the same time. Then you might have issues.
Greg, Janelle, Tenley, & Ellis
2019 Palomino Puma QBSS
TV: 2015 Silverado Z71
Other toys: 2007 Rinker Captiva w/Monster tower & rack
07-29-2020, 01:30 PM
It shoul;d be fine just have the correct dog bone adapter.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-29-2020, 01:36 PM
I do it anytime the 50amp is available at my site. I figure if something trips, it'll be in the camper before the pedestal. That way I don't have to walk outside to reset it.
Why does it trip? Usually the wife running the hairdryer without turning off the AC (the HW Heater element is on, too). Happens at least once every trip.
I usually run a piece of duct tape over the connection between the camper cord and the dog bone to keep water out if it rains.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
07-29-2020, 01:38 PM
Order a RENOGY 50 TO 30 amp adapter at Home depot. You have to type in RENOGY to find it . Under 15.00 dollars ,and free pick up . arrives fast. Remember to check prongs frequently for scorching. No adapter lasts forever.
07-29-2020, 01:43 PM
Thanks to all. I'll pickup and adapter and carry it in the rig.
07-30-2020, 12:55 PM
I always carry one with me. On our last outing, everything was working great until I turned on the AC. Ac tripped the 30 pedestal breaker, never had this happen before, so I figured a weak breaker in the ped. so I used my adapter on the 50 amp side, and problem solved.
07-30-2020, 12:59 PM
Not a problem. But understand, you will still have only 30 amps to work with.
2018 Forester 3011 DS
07-30-2020, 02:30 PM
PhD, Common Sense
Actually, assuming that the 50-amp receptacle has a properly working 50-amp breaker, there will be 50 amps available throughout the length of the 30-amp cable, all the way until the first working 30-amp breaker, likely your RV’s main breaker.
After that working 30-amp breaker, there will only be 30 amps available.
07-30-2020, 02:58 PM
Just as confused as you
You need to turn off the pedestal breaker when plugging / unplugging. If you do not then every time you plug in or unplug there is arcing while the breaker is live.
Richard & Jill
07-30-2020, 03:55 PM
That's a lot of words to simply say that you agree.
07-30-2020, 04:13 PM
PhD, Common Sense
I didn’t agree. I didn’t want anyone left with the impression that there was no way that 50 amps would come roaring down that cable from that 50-amp receptacle. The post I was replying to left that possible misimpression.
The only thing that stops the 50 amps is the trailer’s 30-amp breaker—if it is functioning. And then only from the breaker forward. Nothing before the breaker is protected.
It is important that folks know that a 50-amp receptacle to a 30-amp receptacle adapter merely adapts the plug and does not reduce the possible current passing through and out of the adapter.
07-30-2020, 04:34 PM
It may be present inside the cord but it's hardly available.
07-30-2020, 04:41 PM
PhD, Common Sense
It is available in the sense that any combination of devices drawing up to 50 amps would cause up to 50 amps to flow down the cable unless and until it was stopped by a functional breaker with a lower amperage.
That is my sole point.
I have made it. I won’t bother to continue. Moving on.
07-30-2020, 05:03 PM
Wow, talk about insisting on the last word.....
Peace!
Dan & Rita D
07-30-2020, 05:13 PM
I run with the 50 amp plug converter all the time. TIP: you can push the 30A to 50A plug connector back up and under the lid of most junction boxes so the rain wont get to the plug. Happy RV'ing
07-30-2020, 06:00 PM
07-30-2020, 07:00 PM
While we’re arguing, someone please settle my own personal dilemma. I have 2-2000 watt Champion inverter generators that I plug together for my trailer. The plugger-inner thing has a 30 amp socket that has to have an RV plug adapter which I don’t have. But it also has a 50 amp outlet and I DO have a 50 amp to 30 amp dogbone. I use what I have so as not to have to buy an adapter. It seems to work fine. Am I creating a potential problem for myself?
07-30-2020, 07:01 PM
The perception that there is 50a of current in your shore power cord the moment you use a dogbone adapter is a common misnomer.
Current can't flow unless there is a load of some sort so just because you are connected to a 50a service, if nothing is drawing current, the electric supply isn't sitting there 'pumping' 50a into your cord, waiting for something to use it.
Since your 30a R/V can only draw 30a before the R/Vs breaker will trip, there isn't an extra 20a of current sitting in your cord. The amount of current (amps) in your cord will only ever be the amount you are drawing through it.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
07-30-2020, 07:02 PM
No.
What you are doing is perfectly fine.
