09-25-2020, 06:29 PM
Old man RVer
Using Furrion mount for observation camera
I just bought a Rockwood Mini Lite 2104S trailer which has the Furrion backup camera mount. I’m going to go with a cheaper setup, probably a Haloview, but want an observation camera, not just a backup camera. I know they make adaptor mounts/cables to use the Furrion mount with other brands, but is the trailer wired only for a backup camera? Can I set it up for observation and, if so, how?
Thanks.
09-25-2020, 07:27 PM
Enjoying Life
It will work. Just have to have running lights on.
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
09-26-2020, 09:32 AM
Retired Panpsychist
Haloview offers a KIT for about $10 that includes a camera bracket with mounting holes spaced exactly for a Furrion mount. Also included is an adapter cable that connects the Haloview camera to the pre-run Furrion power cable.
As TeachTexas posted, the camera is on whenever your TV lights are on. We always travel in the daytime with our park lights on so the Haloview gives us a wonderful view of the traffic behind us!
It takes a bit of experimentation aiming the camera's field of view, but it's wide-angle enough to work as a backup camera as well as an observation camera.
FWIW, you should also be thinking about where/how you will mount the rather large 7.5" by 5" monitor. Plenty of posts on that issue already.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
09-26-2020, 11:05 AM
Trailer Park Supervisor
That Haloview adaptor worked great, but I had to pull the sharkfin off. The corner holes match perfectly with holes on trailer wall once you pull fin off. I found no way to make it work in CONJUNCTION with fin. No big deal. The fin mount is just a way to make people feel compelled to get a Furrion Camera.
Yes, I drink the water!
09-26-2020, 01:50 PM
Retired Panpsychist
+1
Some reuse the fin's rubber gasket but I tossed all of it.
Theo & Carol
09-26-2020, 08:14 PM
The camera is the easy part..... I spent 4 days figuring out where to put the monitor. I finally made a mount that keeps the Haloview mount in full visibility with access to all functions. It does not obstruct access to any Dash controls what so ever.
I also went with the Holoview side mount cameras.
09-27-2020, 06:54 AM
Old man RVer
Thanks for the info, guys. I will get on buying and installing the camera.
Not sure yet about the screen mounting. The truck already has a ham radio installed on the dash so it’s a little cluttered. I figure something out. Can I have the wife hold it for me?
09-27-2020, 07:35 AM
I put some Velcro straps on the monitor and strap it to the rear view mirror
2020 Alpha Wolf 26DBH-L
2016 GMC Sierra 1500 Z71 CCSB
10-04-2020, 11:35 AM
FWIW, to mount the monitor. I ran a couple of womens hair bungees around the monitor before putting on the glare guard. Put the thumb screws into the side. This setup holds the monitor on my rear-view mirror securely at very low cost. Easy on and off.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
10-04-2020, 12:45 PM
Attachment 240042
That's how mine looks, minus the cord hanging down. That would bug me. I ran it around windshield under edge of headliner and down A pillar.
10-04-2020, 02:14 PM
Old man RVer
Thanks for the info, guys. The Haloview camera and monitor are installed. Removing the Furrion camera mount was no small job due to the amount of sealant around it (not complaining). Cut into the wire, spliced the Haloview adapter in, mounted and resealed the camera. The monitor sits on the Ford Ranger's dash shelf just fine.
