Old 09-25-2020, 06:29 PM   #1
Old man RVer
Using Furrion mount for observation camera
I just bought a Rockwood Mini Lite 2104S trailer which has the Furrion backup camera mount. Iím going to go with a cheaper setup, probably a Haloview, but want an observation camera, not just a backup camera. I know they make adaptor mounts/cables to use the Furrion mount with other brands, but is the trailer wired only for a backup camera? Can I set it up for observation and, if so, how?
Thanks.
2WheelJon is offline   Reply With Quote
Old 09-25-2020, 07:27 PM   #2
Enjoying Life
It will work. Just have to have running lights on.
2019 Rockwood 2608BSD 2019 F250 4x4 6.2
ďLife should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!Ē - Hunter S. Thompson, The Proud Highway: Saga of a Desperate Southern Gentleman, 1955-1967
TeachTexas is offline   Reply With Quote
Old 09-26-2020, 09:32 AM   #3
Retired Panpsychist
Theo's Avatar
Haloview offers a KIT for about $10 that includes a camera bracket with mounting holes spaced exactly for a Furrion mount. Also included is an adapter cable that connects the Haloview camera to the pre-run Furrion power cable.
As TeachTexas posted, the camera is on whenever your TV lights are on. We always travel in the daytime with our park lights on so the Haloview gives us a wonderful view of the traffic behind us!
It takes a bit of experimentation aiming the camera's field of view, but it's wide-angle enough to work as a backup camera as well as an observation camera.
FWIW, you should also be thinking about where/how you will mount the rather large 7.5" by 5" monitor. Plenty of posts on that issue already.
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
Old 09-26-2020, 11:05 AM   #4
Trailer Park Supervisor
NJKris's Avatar
That Haloview adaptor worked great, but I had to pull the sharkfin off. The corner holes match perfectly with holes on trailer wall once you pull fin off. I found no way to make it work in CONJUNCTION with fin. No big deal. The fin mount is just a way to make people feel compelled to get a Furrion Camera.
NJKris is offline   Reply With Quote
Old 09-26-2020, 01:50 PM   #5
Retired Panpsychist
Theo's Avatar
+1
Some reuse the fin's rubber gasket but I tossed all of it.
Theo & Carol
Old 09-26-2020, 08:14 PM   #6
Villagerjjm's Avatar
The camera is the easy part..... I spent 4 days figuring out where to put the monitor. I finally made a mount that keeps the Haloview mount in full visibility with access to all functions. It does not obstruct access to any Dash controls what so ever.
I also went with the Holoview side mount cameras.
Villagerjjm is offline   Reply With Quote
Old 09-27-2020, 06:54 AM   #7
Old man RVer
Thanks for the info, guys. I will get on buying and installing the camera.
Not sure yet about the screen mounting. The truck already has a ham radio installed on the dash so itís a little cluttered. I figure something out. Can I have the wife hold it for me?
Old 09-27-2020, 07:35 AM   #8
I put some Velcro straps on the monitor and strap it to the rear view mirror
NECamper is offline   Reply With Quote
Old 10-04-2020, 11:35 AM   #9
SailorSam20500's Avatar
FWIW, to mount the monitor. I ran a couple of womens hair bungees around the monitor before putting on the glare guard. Put the thumb screws into the side. This setup holds the monitor on my rear-view mirror securely at very low cost. Easy on and off.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 10-04-2020, 12:45 PM   #10
NJKris's Avatar
Attachment 240042
That's how mine looks, minus the cord hanging down. That would bug me. I ran it around windshield under edge of headliner and down A pillar.
Old 10-04-2020, 02:14 PM   #11
Old man RVer
Thanks for the info, guys. The Haloview camera and monitor are installed. Removing the Furrion camera mount was no small job due to the amount of sealant around it (not complaining). Cut into the wire, spliced the Haloview adapter in, mounted and resealed the camera. The monitor sits on the Ford Ranger's dash shelf just fine.
camera, furrion, mount
