I have a 2016 Cedar Creek Silverback 29RE and have a couple of questions about the plug that the central vacuum is plugged into in the pass thru storage area. There is only a single plug in. Is there any reason this should not be or could not be changed to a double plug in. The reason for wanting a double plug in is so that we could also plug in one of those small (cube) refrigerators. Would use the refrigerator to keep drinks cold and easily accessed when outside the unit.
Thank you for any help with this question!!
I am sorry if this has been discussed and answered before. I looked but couldn't find anything.
There's no reason why that can't be replaced with a dual outlet. Just be careful of how much load you have running off it. Is it a dedicated circuit (only that outlet off the breaker), or is it in combination with other outlets? Both a fridge and the central vacuum connected at the same time may overload the circuit.
