10-03-2015, 10:20 PM
Want to upgrade ceiling speakers...
I have 4 of the incredibly crappy, white wedge shaped speakers mounted to the ceiling of my new trailer. I have upgraded the stereo and now want to upgrade the speakers. I have no problem cutting holes in the ceiling to install new 5.5" or 6.5" coax speakers. Question is, how much clearance do I have between the inner and outer ceilings? Anyone done this mod?
You can see 2 of the 4 crappy units mounted to the ceiling in the attached pic....
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
10-04-2015, 10:27 AM
pull one out an measure the distance
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
10-05-2015, 02:11 PM
About two inches, i installed 40$ 3 way Kenwood s made a world of difference. Dont expect too much bass though.
10-05-2015, 02:12 PM
Btw they were 6 3/4
10-05-2015, 07:54 PM
What type of trailer do you have? Just curious about fit...
10-05-2015, 08:02 PM
best to take one out and measure to be safe. You could have had one out faster than you posted the question
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
10-05-2015, 08:06 PM
phat phrog stunt crew
Bose surround sound. They still surface mount but will beat just about anything out there.
Sent from ny nook using fairly accurate digits.
10-05-2015, 08:08 PM
probably not room for them. Slide will knock them off. Not much clearance between slide top and ceiling
10-06-2015, 09:40 AM
Already dropped a speaker down. These are surface mount, so no hole in ceiling except tiny one where speaker goes through. Even if I stuck a think screwdriver into the wire hole to determine depth, I would have no idea if there is a roof bow/support nearby the would not allow mounting of a regular speaker flush mount.
10-06-2015, 09:56 AM
Put covers, re-fish wire, mount speakers elsewhere?
10-06-2015, 10:15 AM
I believe your ceiling/roof is 4" thick.
Bruce
10-06-2015, 12:38 PM
You are correct about the sound from the POS speakers in the Vibe! What "upgrade" did you already do? Please let us know how your project progresses!
2016 Vibe 268RKS
2015 Chev 2500HD
10-06-2015, 03:06 PM
Looks like you might fish a wire and put a speaker over the refrigerator and the other one could be mounted on the side of the cabinet?? If choosing in-ceiling speaker, be sure that is the right kind for the air space behind it. Acoustic suspension speakers need a specific air space to cushion them. Automobile sound places can probably give you the best advice.
10-07-2015, 05:33 AM
MCTroy
We are looking at an upgrade to the radio, surround sound, blue tooth system next year. Did you run your tv through this unit to?
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
10-07-2015, 09:42 AM
Yes, stereo doesnt have HDMI, so I used RCA cables from tv to stereo. Runs through my ceiling speakers, thus my need to upgrade the tin cans attached to my ceiling...
No surround on this model stereo though..
10-18-2015, 10:24 AM
Dropped down the speaker, peeked in through the hole where the wire comes through.... maybe an inch or two, and a wooden beam of some sort right there.... going to look at drop down 5 1/4" or 6 1/2" speakers. Anyone know where I can buy the round plastic spacer rings that will allow me to flush mount these speakers to the ceiling?
10-18-2015, 01:49 PM
Your new speakers will come with cut out templates, and grilles to cover them.
10-18-2015, 09:14 PM
Yes, but I don't have any space above the ceiling to fit the back side of the speaker, so I need something to space the speaker down from the ceiling.
10-18-2015, 09:32 PM
Hmmmm..... I only had about 2", whre the insulation was. Dont you have room between ceiling and roof?
