Old 09-27-2020, 04:34 PM   #1
Old man RVer
Waterproofing external electrical connections
Why do they do this - electrical connections on the front of the frame subject to road grime and filth.
The trailer is new and I want to enclose the two circuit breakers and battery disconnect shown in the photos. Looking for some type of waterproof enclosure (no, not Tuperware) to mount these devices in. I'd like to do it now before things get mucked up.
Suggestions appreciated. Thanks.
ID:	240085   Click image for larger version
2WheelJon is offline   Reply With Quote
Old 09-27-2020, 04:39 PM   #2
Just Tryin' to Help
cboss's Avatar
You might also google "Liquid Electrical Tape". Lots of the loggers in this area use this. Once it dries, it's waterproof. Easy to apply and it is removable, but not easily. I did all of mine three years ago and have had no problems.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 846
cboss is offline   Reply With Quote
Old 09-27-2020, 06:12 PM   #3
That stuff is great for waterproofing. Just make sure you check terminals for tightness before applying. Stuff is nasty to remove if you have to do any work on terminals.
Also keep off skin. Sticks there too as nd you either have to scrape it off oe wait a week or so for it to fall off.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 09-28-2020, 11:33 AM   #4
Head Rambler
How about a Carlon box or two with some CGB's (Cable Gland Bushings) for the wires?
Gotta go campin!
Old 09-28-2020, 12:57 PM   #5
Mount a marine or waterproof enclosure box for all of your components. https://www.polycase.com/waterproof-enclosures
All cables should pass through a cable gland. https://www.polycase.com/cg1
x90rider is offline   Reply With Quote
Old 09-28-2020, 01:06 PM   #6
TimVWulp's Avatar
liquid electrical tape is the best way to protect the wiring connections. A box or an enclosure will hold water in it and really make a big mess. It is very hard to make any electrical enclosure water tight!!! As an electrician I have opened up a lot of water tight enclosures to drain the swimming pool and replace/clean up the mess that happened from the water in the box.
TimVWulp is offline   Reply With Quote
Old 09-28-2020, 03:42 PM   #7
To some folks this will sound crazy but started doing this about 45 years ago as recommended from a friend. Make sure all terminals are clean, then all connections are tight. Use Vasoline rub, with an acid brush, to coat the entire connection and back on the wire also. This works exceptionally well on FLA battery terminals. Yes they get a little dirty at times and every now and then when doing regular maintenance I will re-coat them. If I need to work on one of the connections for what ever reason I just wipe all terminals with a rag, put it back together and re-coat with Vasoline. I have tried using other petroleum jelly's and have found NONE that works anything like Vasoline. For me I have found this to be a very inexpensive way to keep my outdoor/trailer connections working.
Chuck
Chuck324 is offline   Reply With Quote
Old 09-28-2020, 06:42 PM   #8
I have a Rockwood 2511. I took all of that electrical stuff off the tongue and out from under the wooden floor. Too much moisture and corrosion. I moved all of those items into an electrical enclosure I installed in the front pass thru. This included the in-line fuses, circuit breakers, battery disconnect, etc. This also gets the battery disconnect behind a locked door.
Bev and Wynn, Iowa City, Iowa
2018 Rockwood Mini Lite 2511S
2015 Chevrolet 1500 LT, 5.3L, 3.42 gears
Iowa City Fix It is offline   Reply With Quote
Old 09-28-2020, 07:13 PM   #9
I use the liquid for most all of my "outside" connections, however I wrap scotch 33 tape around those connections prior to applying the liquid tape. Difficult at some connections, but worth it, should you ever have to work on them at a later
date...
Stormy Dayton is offline   Reply With Quote
Old 09-28-2020, 11:50 PM   #10
Put some of this on top of it. Then wipe off when you need to do something with the connection.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
babock is offline   Reply With Quote
Old 09-29-2020, 06:00 AM   #11
^^^X2
Been using it for years on boats in salt water as well as cars and trailers. Any connection that could get wet or is in a corrosive environment.
Hobienick
2020 Rockwood Roo 19
2012 F150 SuperCrew Ecoboost
hobienick is offline   Reply With Quote
Old 09-29-2020, 06:52 AM   #12
I was looking at those exact enclosures for our 2018 Cherokee......then we sold it.
TheWolfPaq82 is offline   Reply With Quote
Old 09-29-2020, 07:47 AM   #13
This is exactly what I use on all exterior electrical connections on our trailer, including chassis ground terminations.
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is offline   Reply With Quote
Old 09-30-2020, 09:09 AM   #14
Chuck
My dad told me to put it on my car battery and now just use Dielectric grease. Never had a problem with either.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 09-30-2020, 10:08 AM   #15
Brake is on left
The Evil Twin's Avatar
Exactly!
The Evil Twin is offline   Reply With Quote
Old 10-11-2020, 09:16 AM   #16
Old man RVer
Waterproofing done
Thanks for all the suggestions. I decided to cover up the exposed electrical connections. The wires are now in plastic conduit, the connections to the battery disconnect are under a tuperware sealed to the frame with silicone and the breakers are now in a water-proof box. The box has a lid with a gasket so that if I ever have to replace a breaker it will be an easy job.
Here are the before and after photos.
Now on to other projects.
ID:	240950   Click image for larger version
Old 10-11-2020, 09:41 AM   #17
Just Tryin' to Help
cboss's Avatar
Great job! Looks really nice!
Craig & Cath
electric, electrical, roo, roof, water
