Old 08-24-2019, 03:15 PM   #1
Wfco 8725p
Have a 2007 Forest River pop-up with a WFCO 8725-P power converter... the converter appears to be producing too much voltage... I went outside today and found that my 12 volt battery was being cooked by the converter... when I put a meter on it, it showed 21 volts.
Any ideas would be appreciated...
Quest0351 is offline   Reply With Quote
Old 08-24-2019, 04:10 PM   #2
Some would replace with the same thing. Many folks take this opportunity to upgrade to Progressive Dynamics to get better battery charging and longer battery life. Your call.
$147
https://www.rvupgradestore.com/WFCO-...-p/55-4720.htm
$99
https://www.adventurerv.net/wfco-amp...k-p-14339.html
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
wfco
