Old 04-11-2020, 01:39 PM   #1
Location: North of I-10 & South of I-94, but East of I-5 & West of I-95
WFCO WF-9800 Series
Hello All
I'm thinking about upgrading to Lithium Ion.
The current charger I have is a WFCO, WF-9800 Series, 65 amp.
Does anyone know if this charger will work on Lithium Ion? If not, why?
I do know there are several Lithium Ion battery manufacturers that have a built in BMS. I would hope the onboard BMS would allow for proper charging.
Thanks for the help
2nd House is offline   Reply With Quote
Old 04-11-2020, 05:26 PM   #2
Nelsflying's Avatar
The Progressive Dynamics Website has a lithium conversion chart for your WFCO converter. I made the conversion last year to lithium. Fairly easy to do.
Nelsflying is online now   Reply With Quote
Old 04-12-2020, 02:53 PM   #3
The reason the standard Lea acid converter is not used for lithium batteries is that the lithium batteries require a higher charging voltage. You can use you existing converter but it does not have the voltage to fully recharge the lithium batteries so the best you will get is a partially charged lithium battery. The BMS in the lithium battery cannot produce the missing voltage.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-30-2022, 12:35 AM   #4
Same charger WFCO 9800
I know this is an older thread. I was wondering if you made the change to lithium. I have the same charger and Iím wanting to to the same upgrade.
Policeboss is offline   Reply With Quote
Old 01-30-2022, 02:43 AM   #5
I changed to a wfco lithium convertor. Was a place selling them on ebay for about $170 shipped. 10 minutes swap.
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
Half Ton Heavy is offline   Reply With Quote
Old 01-30-2022, 06:42 AM   #6
what one did you use
PETEWOOLF is offline   Reply With Quote
Old 01-30-2022, 08:13 AM   #7
TowPro's Avatar
Here is a reputable place selling them. I have purchased 2 non lithium from them and was recommended to them by others that were happy with the company. I have bought the boondocker series from them because of the better warranty.
TowPro is offline   Reply With Quote
Old 01-30-2022, 08:56 AM   #8
If you have solar panels it's not a requirement. The panels will top off the LFP batteries where the converter fails to do so. If you don't have solar you do need a compatible converter/charger.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
wfco
