Originally Posted by cboss
Our WFCO 9855 died today when we got to our new CG (blows the conv AC breaker).
I plan to replace it with a Progressive Dynamics PD9260CV.
Is it "plug and play"?
Any issues?
Has anyone done this?
Thanks in advance.
If your converter is a "Deck Mount" screwed to the floor or wall somewhere other than inside the power distribution panel, it's pretty much plug and play.
If it's inside the power panel then no and you'll either have to modify the space in the power panel or replace it with a PD4655.
If it looks like this you can use the PD9260CV
If it looks like this you'll need a PD4655 converter replacement
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
