Old 07-22-2021, 02:46 PM   #1
kayakist's Avatar
What is this in my battery compartment
Can anyone identify what this is and what it does. It is connected to a positive terminal via a red wire and the label says 10A max. Two pics are of the same item with different view.
I'm going to install a BMV 712 battery monitor. I hope this doesn't interfere or complicate the install.
Appreciate any help you can render.
Thanks!
ID:	259600   Click image for larger version
2021 Coachmen Pursuit 29SS
U.S. Navy Senior Chief (Ret) CTA Rating
kayakist is offline   Reply With Quote
Old 07-22-2021, 03:14 PM   #2
Kanadian Kamper
kenandterry's Avatar
Thanks!
It’s possibly one of a few things that I’ve seen hardwired like that before……
The motorized awning, power steps, propane detector, stereo?
Like I said it’s just a guess.
Pull the fuse out and see what doesn’t work.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 07-22-2021, 04:26 PM   #3
Trailer Park Supervisor
NJKris's Avatar
Maybe goes to 'solar on the side' connector?
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 07-22-2021, 07:56 PM   #4
Brake is on left
The Evil Twin's Avatar
Looks like a water tight fuse holder.
The Evil Twin is offline   Reply With Quote
Old 07-22-2021, 08:00 PM   #5
Shouldn't interfere with BMV 712 install as shunt is installed on negative terminal and every other connection to negative terminal of battery is then installed to other end of shunt from end connected to battery.
ALL current in or out of battery has to flow through shunt.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 07-23-2021, 10:14 AM   #6
Any chance it goes to the breakaway switch?
Tabasco_Joe is offline   Reply With Quote
Old 07-23-2021, 11:18 AM   #7
njfishing's Avatar
Yep looks like a 10 amp fuse that goes to something that needs to be direct wired to the battery.... Perhaps a tongue jack?
In any case, it should not interfere with your Battery Monitor..
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is offline   Reply With Quote
Old 07-23-2021, 01:01 PM   #8
U.S.ArmyVeteran's Avatar
All of the above are possibly correct.
Now, drum roll as we wait for conformation
U.S.ArmyVeteran is offline   Reply With Quote
Old 07-23-2021, 01:07 PM   #9
X2
Could be for any number of possible things that need to be connected to constant power (not switched or disconnected) but yet fused for protection.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-23-2021, 05:12 PM   #10
Tom48's Avatar
The year make and model of your rig makes it easier for us to second guess.
But I'm with everybody else it's either a dealer installed accessory like the tongue jack or for that matter possibly factory installed tongue jack or auxiliary solar input.
As long as it's good gauge wire fuse appropriately, if it ain't broken don't fix it.
The shop for your battery monitor has to go from the negative side of the batteries before anything else touches that negative side and then on the far side of that shunt your frame ground your solar negative you're any other negative that's coming anywhere near those batteries goes on me far side of the shunt away from the battery. And the shunt will want a little 12 + volt input with a little red wire that came with mine. That can go straight to the battery or any other point where there's 12 volt + continuously
Tom48 is offline   Reply With Quote
Old 07-24-2021, 07:39 AM   #11
Some good speculation on the identity of this power wire. I would vote with the tongue jack or breakaway. If you want to pursue its identity, you could always pull the fuse and see what no longer works.
jjuscg is offline   Reply With Quote
Old 07-24-2021, 06:07 PM   #12
Following
campers302 is offline   Reply With Quote
battery
