04-18-2021, 08:22 AM
What is this switch?
Hi! I have 2 light switches in my 2017 wildwood 27rkss. The one on the left is the master switch for the interior lights and the other I cannot figure what it is. I have turned all the lights on, inside and out, and shut it off and on and cannot figure what it goes to. Does anyone have the same model that can explain it to me? Thanks!
04-18-2021, 10:48 AM
Take a pice of the panel so folks know what you are referring to and you should get an answer to your question. Pics are worth 100 posts.
Retired Navy
2016 Flagstaff 26 FKWS
04-18-2021, 10:59 AM
It’s the one on the outside or the right side when looking at it.
04-19-2021, 09:12 AM
Do you have an awning with a light? on my camper, that switch is for the outside LED lights.
Howdy from Texas!
2021 WildWood FSX 178BHSKX
04-19-2021, 11:00 AM
Mine is similar . Do you have led lights on the inside of the slideout behind the wood trim? Maybe the wiring has gone bad??
04-19-2021, 12:26 PM
I do have LED lights that are along the awning. I turn them on with the remote. That switch does not seem to override them. I have tried having them both off and on and flipping the switch and nothing happens.
04-19-2021, 01:07 PM
Ceiling fan?
05 Cummins 3500 dually 2014 Blue Ridge 3025RL
04-19-2021, 01:13 PM
I checked. Nope. No LED lights inside. Thanks!
Awning lights on mine
2017 Chevy Silverado 1500 4wd
2019 Wildwood FSX 260 RT
2012 Harley Davidson Street Glide
2022 Yamaha Wolverine RMAX2 Sport
No, I do not have a ceiling fan
04-19-2021, 01:26 PM
May have been the switch the dealer used on prior years for the outside lights, but now with remote it isn't needed anymore, but they still use the same panel.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
04-19-2021, 01:47 PM
Have you actually looked at the backside of the switch to see if there are wires connected and have you put a meter on them to see if the switch sees power. It is not uncommon to use a plate, and fill the plate with an empty switch -
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
04-19-2021, 02:07 PM
Go into the TT at night and see what you see.
04-19-2021, 02:23 PM
Do you have a light on your hook up side? I had a MH that had a light on that side incase of hooking up or unhooking at night. It did come in handy one time.
Henry & Tena
04-19-2021, 03:03 PM
In some units that switch controls a led light strip at the base of the awning.
Mark & Heather
Mountain Falls, VA
2019 Salem FSX 179DBK
04-19-2021, 03:10 PM
Awning light on mine too.
04-19-2021, 03:35 PM
On mine the right "light" switch is for the awning LED lights, the other is for the scare light over the entry door.
2016 Salem 27RKSS
04-19-2021, 03:36 PM
Mine controls the led light strip and the yellow light behind the steps at the door. really hard to see the light, IF not dark outside. the fuse for these are inside my pass thru.
2016 Salem Hemisphere 312 QBUD
2019 F250 Diesel
04-20-2021, 06:31 PM
Do you have a remote for your awning light, as well?
04-26-2021, 09:50 AM
Yours may be like mine not sure. I don't have access to my TT to verify this but I think the awning lights work like the inside overhead light nearest the panel. On the panel, my switch closest to the door operates the overhead light. The other operates the awning led light strip. This always seemed like it should have been reversed to me.
But if the panel light switch is turned on, you can turn the overhead light on or off at the fixture. If the panel light switch is off, the switch on the fixture doesn't work.
In the case of the awning light, the remote works like the switch on the fixture.
Our bathroom fixture works the same way between the wall switch and the fixture switch.
I hope that makes sense.
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
Days Camping -
'15 (6) : '16 (32) : '17 (41) : '18 (35) : '19 (38) : '20 (15) : '21 (15) :
