12-04-2017, 09:14 AM
What should run on battery only
I've got a Salem 27DBK. What circuits typically work when running only on batteries? My residential fridge runs but no other 120 volt circuits. Should the outlets be energized?
12-04-2017, 09:18 AM
That is correct. Normally the only 120VAC appliances that will work are the fridge. Outlets, tv, AC, and microwave will not. The stock battery bank and inverter are usually not large enough to handle much more. This should have been covered by dealer during PDI, but many do not.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-04-2017, 09:19 AM
Your fridge is probably on an inverter. Depending on how many batteries you have only the fridge is on there. Otherwise your batteries would be toast
Sent from my LG-H910 using Forest River Forums mobile app
12-04-2017, 10:01 AM
Thanks.... Just wanted to make sure all is working right. On our way Dec 15 for Xmas trip.
2017 GMC Z71 4WD
Custom 8 Inch Lift
Blue Ox WDH
2018 Salem 27DBK
12-04-2017, 10:04 AM
Thumbs up, have a great trip
12-04-2017, 10:11 AM
Insert witty title here
Your 12V system should also run your lights, propane furnace and propane water heater.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
12-04-2017, 11:26 AM
Location: Alberta - East of the Rockies, West of the Rest
But don't expect to get more than a couple hours out of a single battery, especially if it's one that was supplied with the trailer.
The fridge, the water pump and furnace fan are heavy users, as are the lights if they still are incandescent bulbs.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
12-04-2017, 02:34 PM
I have just discovered that my residential fridge is hooked up to the 12 v battery system which converts the 12v to 120/1/60. My converter just went out, so I have no 12v to the lights, etc. Fortunately the slides operate directly form the battery so I can at least move the rig to the repair shop in Santa Fe to get the damn thing fixed
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
12-04-2017, 03:05 PM
Your lights are 12V and should work from battery as well. if they are not working, check fuses. If slide works all 12VDC items should work
TST Tire Monitors
2 100W solar panels
12-04-2017, 06:29 PM
Senior Members
Your slides run off your batteries.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
12-04-2017, 06:38 PM
The only things that won't work off the batteries directly are the wall outlets, AC, microwave, electric heat, electric hot water and TV.
12-04-2017, 06:52 PM
Empty Nesters
Unless you have a DC Voltage TV like I do in my Sunseeker!
2017 Sunseeker 2250 24' MH
12-05-2017, 11:54 AM
We used to have an 06 Flagstaff TT,,, the hood light & fan ran on 12v only ???
12-10-2017, 05:10 PM
Very helpful info! Thank you!
12-10-2017, 05:53 PM
Had to replace the entire converter set up
Kayo
12-10-2017, 06:45 PM
UNLESS you have a battery disconnect switch and you somehow have turned it off.
2011 Traverse LT, 3.6L, FWD
12-10-2017, 06:49 PM
If the slides are working, it's safe to say the 12V disconnect is still on.
12-10-2017, 06:56 PM
Most likely, but not necessarily. Some folks here on the forum have reported that their slides and power jack (and CO monitor) are powered directly from the battery.
12-10-2017, 07:07 PM
Then battery isn't disconnected.
