I will keep it simple and safe and run 2awg from the battery negative to the ground.
As for the other charger case ground to chassis, the charger will normally be plugged into a 20a AC circuit from power center. However, when I run the generator, which is located on the tongue, I didn't want to pull my shore power cord out and run it all the way from the rear of the RV to the tongue. I was thinking instead that I would wire an outdoor outlet right at the generator location to a new outlet located just next to the 20a AC outlet from the power center. This way, when I want to run the generator, I'll just reach in the front compartment and move the charger plug from AC power center outlet to the generator outlet. I know there are switches for doing that but they looked very expensive and it would be just as easy to unplug and plug the charger outlet.
Does this make sense, or am I planning this wrong?
So when the charger is plugged into the generator directly there will be no link to the AC power center chassis ground, so I think I need to ground the charger box. Since the generator breaker is 15amp, amd I wrong to just go with like even a 12 awg wire for the charger ground to chassis?
FYI, the generator is a Honda 2200.
Thank you
2020 Ford Expedition XLT
2021 Rockwood Roo 235S
