Closed Thread
Old 09-12-2018, 08:53 PM   #161
Not too worried about utility workers. They are well aware of clowns and their generators. They disconnect and work between grounds, always. I have 10KW of solar panels in a grid tie system and it is all to code. There is a disconnect switch but not a transfer switch, automatic or otherwise.
However, I am worried about you.
RV- 2014 Thunderbolt XLR 386X12 Called "The Castle"
TV- 2013 Ram 3600 DRW Diesel Called "Hercules"
rick42wood is offline
Old 09-12-2018, 08:56 PM   #162
Originally Posted by spock123 View Post
Is there anyway to delete a post you have made on the forum? This is one time I should have said nothing. After all thatís what I got
Forum rules will not allow me to respond to this. I wish you well and I will pray for your safety.
cavie is offline
Old 09-12-2018, 08:57 PM   #163
What you got was an answer you didnít want to hear! What you are attempting is dangerous for not only you and your property but others as well. A statement that the lineman should assume the line is energized is just plain ignorant. That lineman may have followed all the proper procedures but your installation is so far out of the norm that he doesnít even consider it a possibility. You need to listen to the professionals here. I too am a master electrician with over 40 years experience and an electrical engineering degree. My comments are more directed to others reading this post. DO NOT ATTEMPT WHAT SPOCK123 IS SUGGESTING - PERIOD.
Actually this whole thread went down the rabbit hole from the beginning and should in my opinion be deleted.
WY Husker Fan is offline
Old 09-12-2018, 09:36 PM   #164
Report it using the red triangle at the bottom left corner as I did.
cavie is offline
Old 09-12-2018, 09:55 PM   #165
wmtire's Avatar
Ok, we are going to close this one for review.
2011 Flagstaff 831 RLBSS
I'm trying to keep up with the Joneses, but every time I catch up, they refinance.
wmtire is offline
Closed Thread
50 amp
