Old 01-03-2018, 04:59 PM   #1
Winterize Solar and Batteries?
I am likely parking the TT for a while and have my solar panels mounted on the roof and batteries connected and stored in the plastic box mounted on the tongue. Currently my solar controller is on keeping the batteries charged. Should I be disconnecting the batteries and storing them inside the garage or leave them hooked up? Do I need a trailer cover for the solar panels or are they ok to leave exposed? Our weather is quite sporadic in Colorado Springs so you could expect below freezing temps or up to 70 degree days in the winter. Thanks!
CO 26DBHer is offline   Reply With Quote
Old 01-03-2018, 05:15 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Check the fluid levels in the batteries (unless you have AGM batteries) once a month and everything is going to be just fine.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 01-03-2018, 05:19 PM   #3
Flybob's Avatar
You don't need to cover the panels. They are very tough. The decision as to leaving on the TT for the panels to keep charged depend on several things.
1. If the panels will see sun ( not covered by snow) at least a few days every week or so. If they will get snow covered for the several weeks then pull the batteries.
2. How secure are the batteries ( from theft)?
If unsure, just pull them and store them fully charged. If you pull the batteries, it is recommended you disconnect the panels from the controller first.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
batteries, solar, winter, winterize
