Old 06-07-2014, 05:38 AM   #1
GC
Wiring a 30 amp outlet
Needing a little electrical advice. I replaced the main service panel in my home and want to add a 30 amp RV outlet out of this main panel. I have wired the correct RV outlet with the correct gauge wire and have run the wire to the panel. Diagram shows black wire to breaker, white to neutral bar and the bare wire to the ground bar. Since this is the main service panel, the neutral & ground are bonded together and not separated like on a sub panel where they are seperated.
Do I just hook the neutral & ground wires to the neutral bar?
GC
GC
garycarson is offline   Reply With Quote
Old 06-07-2014, 05:43 AM   #2
Yes, GC, that's exactly what you do.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 06-07-2014, 05:45 AM   #3
fonzie's Avatar
Black to breaker, white to neutral bar and bare conductor to ground bar. (this is the way that is done in Ontario, yours might differ)
Fonzie
Old 06-07-2014, 05:52 AM   #4
I think he is talking about a breaker panel where there is only one buss bar for the neutrals and ground. If that's the case, they go together. If there are separate ground and neutral bars they should go to their respective buss bars.
Old 06-07-2014, 05:53 AM   #5
fonzie's Avatar
Got it, true......
Fonzie
Old 06-07-2014, 06:37 AM   #6
Herk7769's Avatar
Main breaker panel has Neutral and Ground wires bonded.
Sub-Panels have separate buss bars since by code there can only be one bonded connection in a system.
Old 06-08-2014, 09:19 AM   #7
Herk7769's Avatar
Here is how to do it.
Just remember it is 110 volts no matter what your electrician friend says ()
Old 06-08-2014, 09:23 AM   #8
dcheatwood's Avatar
Good info. Is it the same for 50amp with larger gauge wire and 50a breaker?
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
dcheatwood is offline   Reply With Quote
Old 06-08-2014, 09:29 AM   #9
Herk7769's Avatar
50 amp is different:
ID:	54629   Click image for larger version
File Type: pdf Top 10 Electrical Mistakes - Vol 1.pdf (452.2 KB, 91 views)
Old 06-08-2014, 11:31 AM   #10
Average Joe
MrJoe's Avatar
What size conductors are needed for a 30 amp, 30 foot run?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 06-08-2014, 11:43 AM   #11
Average Joe
MrJoe's Avatar
Never mind. Found it... 10/3
Joe and Karen
Old 06-08-2014, 08:16 PM   #12
dcheatwood's Avatar
Thanks herk.
Old 06-09-2014, 05:52 AM   #13
GC
Thanks everyone for your responses and diagrams. I'm wired up, plugged in and the air conditioner is running. Life is good!!
Have a great camping season.
GC
Old 06-14-2014, 07:19 AM   #14
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
I would like to do this at my place also. How can I tell if I have room on the main panel? Is it a matter of adding up the current breakers in amps? Also, can I bury the wire under the ground and if so how deep?
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
Old 06-14-2014, 08:16 AM   #15
If you have breaker space you will be OK to add the new rv circuit. There is a formula to calculate load but it is very long and no need to run it u less you have a 100 please service.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
wiring
