wiring issues
I have a cargo trailer with the 110volt upgrade. I have built cabinets in the nose and am getting ready to load up my bikes, when I noticed that the back outlet near the ramp, and the outside gfci are not working. The outside gfci will not reset, and the inside outlet shows with a tester that the hot and ground are switched. I pulled out all the outlets on that circuit and checked them out, and they are wired correctly. This is telling me that the wire is pinched somewhere in the run, from improper installation. Problem is that the inside is finished with plywood, walls and ceiling.
Questions is this. Does anyone on here know how they run their wires? Are they in the steel framing in the walls. Are they in the ceiling? Or in the 45 degree metal trim where the ceiling meet? I am hoping to fix this my self rather then take it to the dealer, as they are a bunch of numbnuts.
thanks for any help you can give
