03-23-2021, 05:54 PM
2 bent axles
I bought a 2013 forest River 29 footer and it has 2 bent dexter axels. I stopped at a trailer repair shop and they say some of the forest rivers didn’t reinforce the frames to good that I should drop the belly pan and investigate that. They mentioned that the cross bats may be to far apart. Any thoughts on this?
Also there is some vertical ripples on the curb side top to bottom next to the left support arm of the awning. Hope it’s not tied to the frame.
03-23-2021, 05:56 PM
Pictures?
03-23-2021, 06:04 PM
Add your trailer info. Like we have in our signature.
2015 silverback 31IK
2023 f350
03-23-2021, 06:31 PM
On a 2013 trailer it is hard to know what the previous owner put it through.
Damage from rough roads, or overloading is very possible. Overloading the trailer or any other misuse can bend or weaken a frame.
As far as a larger frame wide issues there were some fifth wheels that Lippert had issues with several years ago. What is your make and model trailer?
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
03-23-2021, 06:39 PM
Tracer Ultralight
2670 BHS
03-23-2021, 06:45 PM
Two bent axels and ripples in the siding? That doesn't sound good.
2015 Dynamax REV 24TB class C
03-23-2021, 06:49 PM
How do you know that the Axels are bent? From what I see, that could just be severe bearing wear.
03-23-2021, 08:08 PM
Think positive lol
Forest River
Tracer Ultralight Signature Series
2680BHS
03-23-2021, 08:13 PM
I laid a straight edge wheel to wheel and believe me it’s bent. I also jacked it up and checked for bearing wear. Good there.
03-23-2021, 08:20 PM
RV trailers are generally not ever straight edge straight. Most I've seen are arched up a little to compensate for weight.
03-26-2021, 05:47 PM
That photo looks exactly like mine on a Forist river after hitting a big pothole! Same tire wear, same visible cant to the wheel. That's from road trauma and I would bet the seller knew it! They just put new tires on it and sold it.
03-26-2021, 06:00 PM
Took the trailer to a dealer. The ripple in the siding was caused from a water leak up top they said. He did confirm the 2 axels were bent
03-26-2021, 06:09 PM
I ordered 2 axels with hubs and electric brakes. $610.00 for both. Great price.
I’ll put new hardware on too. Go big or stay home lol
Thanks for your response. Happy camping and safe travels
03-26-2021, 06:22 PM
I would be very concerned about the water leak that caused the sidewall to delaminate... have you checked for mold in the walls and roof?
2014 Shamrock 183
03-26-2021, 06:34 PM
Thank you for your reply! Not sure how I’m going to check the walls for mold. Is that even possible?
As far as the possible roof leak goes there is a Big vent on the side and location that the dealer thought could be the Culprit. I’ll have to get the ladder out to check. Recommendation for caulking the vents / AC ?
03-26-2021, 06:39 PM
Do you smell any musty/moldy smells in that area? There are mold test kits available on amazon. Mold is nasty and a prime reason trailers are junked. Drill some small holes into the walls/roof... they should not be black.
Delamination, where the fiberglass peels away from the outside wall is usually a result of water getting into the wall... this might be the ripple you speak of.
Read this post of how I sealed my roof from leaks for a long time...
https://www.forestriverforums.com/fo...nce-90060.html
2014 Shamrock 183
03-26-2021, 06:57 PM
Cool stuff rsdata! Can a guy put that around the vents and AC?
03-26-2021, 07:08 PM
Eternabond tape can replace caulk anywhere. It is sold in various colors/widths from 2 inches and up. Applied properly it will stick for 10 years with a warranty. Go to eternabond dot com for more info.
I am going on year 5 of mine and no signs of deterioration of the tape or pulling up.
I did edit and add a bit to my previous post, so make sure you read it again.
2014 Shamrock 183
03-26-2021, 07:15 PM
I sure will. I’ll check that website out. I forgot to answer your question about smell on the interior, no smell what’s so ever. The interior on this 2013 is mint condition. At least I got that going for me (:
Have a blessed weekend! Happy travels my friend👍
