Old 04-10-2019, 08:38 PM   #1
3 more reasons to inspect your brakes
I decided to pull the wheels and inspect my brakes instead of just greasing the wheel bearings with the easy lube zerk fitting. Glad I did, here is what was inside one of the brake drums. Could have been real bad if the sheared off bolt had jammed and caused the wheel to lock up.
ID:	201412   Click image for larger version
ID:	201413   Click image for larger version
2015 Ceder Creek 38FB2
2016 F350 Dually Diesel
srosey is offline   Reply With Quote
Old 04-10-2019, 11:23 PM   #2
Fluffywhitedogs's Avatar
No idea what I’m looking at but sounds like it could have been really bad! Glad you found it!
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is offline   Reply With Quote
Old 04-10-2019, 11:43 PM   #3
clarkbre's Avatar
I'm scared to see what mine look like but I need to do it. It'll be the first time cracking them open after buying and towing our trailer nearly 4700 miles.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 04-14-2019, 09:09 AM   #4
SilhouettePenny's Avatar
That threaded bolt mounts at the bottom of, and separates, the brake shoes with a slotted star adjustment wheel which appears to be missing. Most likely those two components chewed up the shoes. Simply measure the diameter of the drum and the width of the shoes then call etrailer for replacement. On a CC they are self-adjusting brakes. Get your oil seals at NAPA, far better than the original.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
brakes
