Waterproofing the bottom of a travel trailer is a bit of a problem.
One could cover the bottom with sheet metal and seal joints but at what weight premium.
Mine is covered (mostly) with a Coroplast (plastic cardboard like material) held in place by Ramset type nails and washers. Does a great job of keeping water off the floor down the center and between frame rails. Rest of exposed surfaces are covered with a synthetic fabric that seems to shed water yet "breathe". Area above the wheels is covered with a heavier gauge plastic which I guess might suffer damage if a tire flew apart but so far none have.
I think that most manufacturers expect RV users will only be using them during good weather and if they do drive in a rain storm, they will sit for days and whatever gets wet will just dry.
My old trailer had it's underbelly covered with a heavy polypropylene fabric that was described as "rodent resistant". Went from front to back and side to side, supported every foot or two by Tek screws and washers. After 22 years of use, no water issues and living up in the Pacific NW I can't count the number of times I drove/towed it in the rain.
Depending on how many obstacles you have to deal with, perhaps sheets of FRP that are available from most any Big Box DIY store could be installed and the area above the wheels given some extra "armor" by attaching some 14-16 gauge aluminum sheeting (extended well ahead and behind where a piece of tire might hook an edge and rip it out).
Just tossing out what I've seen on mine and an idea.
BTW, if you do close up the underbelly, make sure to add a couple of louvered vents (the little round 2-3" type) so moisture has an escape path should any make it's way above the covering. Trapped moisture is the biggest cause of rot, mildew, etc.
