Originally Posted by GrayghostUSA
Thanks for responding. I have already done google searches. The ones I have talked to want me to tow the trailer there to even decide if they can do it. Obviously I want to minimize towing only to be told they cannot fix it. I am hoping for some personal response/experience.
Tim Shannon
From what the pictures show, it seems to me that towing the trailer in this condition would be a big risk. You
might get away with it, but I suggest either a mobile welder or a flatbed tow.
The direction of the bend is consistent with excess weight forward of the trailer axle and/or a lack of adequate frame strength. A WDH would have actually served to
reduce the bending stress in this case.
Some of the little 13’ molded fiberglass trailers from the 70’s are notorious for failing in a location similar to yours. It’s a location that bears a lot of stress.
Personally I’d prefer to see a continuous member running along the bottom of the A-frame and back towards the axle, rather than separate parts welded to a transverse member as it appears your trailer has.
Am I correct that the A-frame is attached closer to the centerline of the trailer than the frame members are? Because it looks like this transverse member is twisting under the stress imposed by two separate sets of attached members.
One set is the two A-frame members forward and the other set is the two frame rails to the rear. It appears they are acting like pairs of wrenches applying moment (rotational force) to the transverse member in opposite directions,
and at different distances from the centerline of the trailer. So, the transverse member is failing and twisting.
FWIMBW, I’m not a structural engineer, but I took related coursework in college and regularly worked with SE’s for 40 years.
In any event, you need an experienced and qualified welder who can evaluate this, at minimum.
Personally, I think that qualified person could look at your first photo and say “yeah, I get it and I can fix it, bring it in”. Unfortunately, the person who answers the phones may not have a clue. So, ask if you can email the shop(s) pictures instead of bringing the trailer in. Hopefully that's worth a shot and somebody will respond with (justifiable) confidence that they can address the underlying issue which appears to be a dodgy, inadequate design.
