Old 08-17-2023, 08:51 AM   #1
GrayghostUSA's Avatar
A frame hitch failure
Houston we have a problem. We got back from a trip to the Outer Banks Monday afternoon. On I-40 and NC 64 we encountered some of the roughest roads we have seen yet. When we unhitched at home we discovered our hitch has bent at approximately 5-10 degrees. We talked/emailed with Lippert yesterday and they said they would get back to us in 2-3 days. So far we have been unable to find anyone here in Greater Atlanta who can fix this. Any suggestions?
Name:	Drivers Side Tongue Bent.jpg.jpg
ID:	291528   Click image for larger version
Name:	Passenger Side Tongue Bent.jpg.jpg
GrayghostUSA is offline   Reply With Quote
Old 08-17-2023, 08:56 AM   #2
Hitch Failure
Houston we have a problem. We got back from a trip to the Outer Banks Monday afternoon. On I-40 and NC 64 we encountered some of the roughest roads we have seen yet. When we unhitched at home we discovered our hitch has bent at approximately 5-10 degrees. We talked/emailed with Lippert yesterday and they said they would get back to us in 2-3 days. So far we have been unable to find anyone here in Greater Atlanta who can fix this. The Trailer is a Flagstaff Super Lite 26RBWS. Any suggestions?
Old 08-17-2023, 09:03 AM   #3
Oaklevel's Avatar
Yikes, If the trailer is not under warrenty........
Yes I did a quick google search and found numerous repair places in the Atlanta area..
Search tailer repair and go from there...... did your RV dealer recommend anyone? It does not had to be an RV dealer.
Good Luck !
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 08-17-2023, 09:09 AM   #4
Thanks for responding. I have already done google searches. The ones I have talked to want me to tow the trailer there to even decide if they can do it. Obviously I want to minimize towing only to be told they cannot fix it. I am hoping for some personal response/experience.
Tim Shannon
Good Luck !
Old 08-17-2023, 09:25 AM   #5
D W
D W's Avatar
This is a duplicate post of this thread:
https://www.forestriverforums.com/fo...ml#post2879996
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 08-17-2023, 09:31 AM   #6
Yes it is. Posted in two different areas for two different possibilities for someone knowing something that would help.
Thanks for the response. Do you know anything that would help us solve our problem?
Old 08-17-2023, 09:34 AM   #7
Chuck_S's Avatar
Got room in your garage for everything in the trailer? I've got a feeling this will best be repaired at a real trailer shop, not an "RV" dealer. It may have to be flat-bedded.
Tongue weight? Which WDH?
Don't worry about answering my questions -- you've got too many problems right now. But I'm sure we'll all appreciate follow up when a solution is reached.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-17-2023, 09:36 AM   #8
you can also search for mobile welder
I would wait for Lippert to get back to you
they may have preferred repairers
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-17-2023, 09:36 AM   #9
NMWildcat's Avatar
Call your insurance.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 08-17-2023, 09:41 AM   #10
Mr. Dan's Avatar
Threads merged to honor guidelines against posting the same content in multiple places.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 83; Booked for 2024 = 42
Old 08-17-2023, 09:43 AM   #11
Contact your insurance company.
I know you have a lot to contend with and the roads are lousy no doubt but there will be questions such as... Were you using a weight distributing hitch?(looks like it) What does the trailer weigh? What is the tongue weight? (noticing the BIG side storage doors in the front) Have you modified the tongue in any way? (added a battery and new box)
Best of luck to you.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 08-17-2023, 01:25 PM   #12
Cringe
I cringe when every time I slip on or off my bars. The bang sound is unnerving. Good luck with your speedy repair.
vestup is offline   Reply With Quote
Old 08-17-2023, 02:16 PM   #13
yes, keep us up to date please.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
Old 08-17-2023, 02:24 PM   #14
You can stop the banging by lowering the trailer jack, which raises the trailer. Turn out on the bars and raise the jack for travel
Larry-NC is offline   Reply With Quote
Old 08-17-2023, 02:32 PM   #15
Do you have a picture that shows more of the underside supports? Where and how is it bending?
Jim M.
Old 08-17-2023, 02:40 PM   #16
RedLdr1's Avatar
I'd call Three Way Campers in Marietta. They have full service department and might be able to help you out. https://www.threewaycampers.com
2024 Sunseeker 2150SLEF on a 2025 Ford E-350 chassis with "Godzilla" 7.3L and 6 speed automatic transmission. "Trekker" Cap, Solar, Suburban IW-60 On-Demand Water Heater, All MaxxAir Fans, Progressive EMS-HW30C, Pacific Dually "Hub Caps".
TOAD: 2024 Ford Bronco Badlands, 2 Door, 2.7L EcoBoost, 10 Speed Automatic, 334A Luxury Package, Leather, Blue Ox and RVi Flat Tow Equipment.
RedLdr1 is offline   Reply With Quote
Old 08-17-2023, 03:32 PM   #17
Part-Time Campground Host
cboss's Avatar
X2. Please post some underneath pics.
Craig & Cath
Days camped since 2015 (retirement): 1733
cboss is offline   Reply With Quote
Old 08-19-2023, 09:09 AM   #18
Cannot see what is bent unless it is the c channel spanning the front of the frame. The A-frame welds to this member seem to be good. The diagonal tubes under the storage area seem to be good.
Name:	Drivers Side Underneath 2.jpg.jpg
ID:	291637   Click image for larger version
Name:	Drivers Side Underneath.jpg.jpg
ID:	291638   Click image for larger version
Name:	Tongue Drivers   Side.jpg.jpg
ID:	291639   Click image for larger version
Name:	Tongue Passenger Side.jpg.jpg
Old 08-19-2023, 09:49 AM   #19
Your first set of pictures from the passenger side the C channel looks bent at the side wall of the trailer. Maybe its an optical illusion?
So your saying the box beams under the trailer look good? How about where they weld into the I beam under the storage box? Thigs look straight there?
Jim M.
Old 08-19-2023, 10:27 AM   #20
old40ford's Avatar
Lippert may even send someone to your home. They have done so for some in the past. Not sure about them these days though.
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
a frame, frame, hitch, ram
