That really is a bad comparison because Goodyear does not build a 15" steel cased trailer tire.
That leaves the Endurance as the only option with Goodyear in a 15" st tire, which is the best they offer in my size, is why I compared it.
I paid $500 installed and balance for 4 Hercules.
Does any one have any experience or knowledge of this tire Trailer King manufactured by TBC? This is what was delivered on Tracer in 2019.
Full DOT serial would be of help and a good start. Did the pictured tire "fail" If so do you have other pictures?
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Is that a steel bodied tire?
LR-F means you will need to run 95 psi to get the LR-F load capacity. Are the wheels rated for 95?
There are a lot of ST tire builders building that size steel cased tire. Probably the most recognizable brand name is Carlisle.
Hercules has a few Commercial grade ST tires.
One 15" and 3 16" worth considering
