Originally Posted by TitanMike
Agree, clean up the threads but don't use emery cloth on journal surfaces. Instead use crocus cloth. It's meant exactly for this purpose, polishing, not grinding. Use new bearing to check for fit. Should be snug and smooth. If you see any nicks or burrs remove them with a small knife sharpening stone and only work that area.
Reassemble with freshly greased bearings, new seal, new nut, and cotter key.
Be sure and monitor hub temps (just feel at stops) regularly and when you return home disassemble and check for signs of the bearings spinning on the spindle. If that's happening you'll want to replace spindle/axle.
I've seen all kinds of tricks like using a center punch around the journal area of the spindle to tighten bearings, even greasing the inside of the bearings, degreasing the journal, and assembling with a thin layer of J-B weld on the journals. Idea is that the J-B will stick to journal, fill gap, and grease film on inside of bearing (where it sits on journal) will allow it to release. Usually not and it makes for very difficult future bearing packing.
I don't believe the spindle is replaceable by itself. If it's any condolence a replacement 3500 axle like yours (assuming 3500#) is just under $400 plus shipping. A lot less than consequences of a lost wheel.
You should highlight "freshly grease bearing".
My anal husband, decided to check out our bearing on our brand new, 2019 Cedar Creek Silverback fifth wheel. Only to find out that non of our bearing were greased and two had to be replaced. This was after putting over a 1,000 miles on the trailer. WHAT the F? We did pump grease into the zert. Why the heck didn't the axle people properly packed those bearing.
Needless to say, they are properly packed now.
