Old 10-20-2019, 10:13 PM   #1
Axles on 2017 Coachmen Apex 239
Bought this camper new, but the dealer didn't include any literature on the axles. Can I presume they are Dexters? Also, as there are zerk fittings on the ends of the axles, can I assume that these are EZ Lube? I can attach a picture of the hub if it helps. Thx.
4Seasons is offline   Reply With Quote
Old 10-20-2019, 11:08 PM   #2
Look on the axle tube for a label. It should have the information you need.
MtBiker is online now   Reply With Quote
Old 10-21-2019, 06:02 AM   #3
Airdale's Avatar
The axle tag provides the axle maximum load. It may not be official unless it matches the vehicle certified GAWRs listed on the vehicle certification label.
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 10-21-2019, 07:04 AM   #4
Think the OP was wondering who the manufacturer of the axles were.
TheWolfPaq82 is offline   Reply With Quote
Old 10-21-2019, 08:16 AM   #5
Brake is on left
The Evil Twin's Avatar
The hub, if original, should have the name on them. All my hub drums are stamped Dexter. EZ lube is Dexters name for it, but Lippert has the same system to pump new grease in. FWIW, if you are looking to lube the hubs, I would pull them all and clean/ inspect/ pack if you have never done so. First time I did so on my trailer I found a galled bearing. Less than 3000 miles.
The Evil Twin is offline   Reply With Quote
axle
